🎉Community Raffle - Win $25
Join and Win
problem with database connection
User: "boudi313"
New Altair Community Member
Updated by Jocelyn
when I define a new sql connection and when I press on the test button this message is shown next:
SSO failed: naitve SSPI library not loaded check the java.library.path system property
please help me
1 - 3 of 31
    User: "MariusHelf"
    This is like calling the doctor and saying "my arm is hurting" - he will probably ask you to come over so that he can have a look at your arm, or at least ask in which situation which part of your arm is hurting :)
    Please post the settings you entered into the dialog.
    Best, Marius
    User: "boudi313"
    OP
    from manage database connection I entered the name of connection then I choose the sql server (JTDS) then I wrote the server name which is my laptop name  after that I press on the test button then the error is appear
    User: "fischer"
    Hi,
    if you need single sign on (Windows authentication), you need to place the ntmlauth.dll library in your Windows path. It is included in the JTDS driver:
      http://sourceforge.net/projects/jtds/files/jtds/1.2.5/
    Otherwise, use the regular SQL Server authentication.
    Best,
    Simon
