text mining filter stopwords (dictionary)
Hello. I have a process to read an Excel file, process documents from data, and create correlation matrix. The process runs fine except when I want to add a filter stopwords (dictionary) after the filter stopwords (English) and before Filter Tokens (by Length). It seems to ignore my list of stopwords (dictionary). I've tried using a csv and txt file for stopwords (dictionary) but the stopwords still show up in the output. I've set preference rapidminer.general.encoding to UTF-8. All the files should be in English. Any ideas?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true" height="415" width="547">
<operator activated="true" class="read_excel" compatibility="5.2.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="E:\R-2.14.0\bin\i386\tickets.xls"/>
<parameter key="imported_cell_range" value="A1:A748"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="Rationale.true.text.attribute"/>
</list>
</operator>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="30">
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="10"/>
<parameter key="prune_above_absolute" value="700"/>
<list key="specify_weights"/>
<process expanded="true" height="434" width="557">
<operator activated="true" class="text:transform_cases" compatibility="5.2.001" expanded="true" height="60" name="Transform Cases" width="90" x="35" y="45"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.2.001" expanded="true" height="60" name="Stem (Snowball)" width="90" x="154" y="49"/>
<operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="40" y="144"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="45" y="255"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="179" y="300">
<parameter key="file" value="E:\Rapid Miner\RapidMiner5\Stop_Dictionary05082012.txt"/>
</operator>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="270" y="225">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="9999"/>
</operator>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.001" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="380" y="165">
<parameter key="max_length" value="1"/>
</operator>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="correlation_matrix" compatibility="5.2.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="54" y="198"/>
<connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="example set" to_port="result 1"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
<connect from_op="Correlation Matrix" from_port="weights" to_port="result 3"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
1 - 9 of
91
your process seems to be okay. How does your Dictionary file look like?
Best,
Nils
