extract information
Hello,
I have got a txt file with more than 100 articles (containing date, headline, text, author).
I want the program to list all the terms ending with -ing, -ion etc. Afterwards i want the program to sort the terms by frequency alphabeticaly. Unfortunately I am a beginner and i dont know how to go on.
The following steps are working at the moment
1. Read txt
2. Tokenize
3. Delete stopwords
After these steps Rapidminer gives me the text without stopword. But how can i make the program to give me
the words with different endings? Is "extract information" the correct input?
1. Read txt
2. Tokenize
3. Delete stopwords
1 - 3 of
31
Why would you want to do that? Anyway, you can use the Binary Term Frequency to just indicate if a token is present in a document or not, as in the process below.
Best, Marius
Best, Marius
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<process expanded="true" height="190" width="480">
<operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30">
<parameter key="text" value="a a b a c b"/>
</operator>
<operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="120">
<parameter key="text" value="a b d a a d d d"/>
</operator>
<operator activated="true" class="text:process_documents" compatibility="5.2.001" expanded="true" height="112" name="Process Documents" width="90" x="246" y="30">
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<process expanded="true" height="536" width="950">
<operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
the Filter Tokens operator is what you are looking for. Set "condition" to "matches" and enter a regular expression like , this should give you the expected results.
Best
Marius
