.*ion|.*ing
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="190" width="480"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="a a b a c b"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="120"> <parameter key="text" value="a b d a a d d d"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.001" expanded="true" height="112" name="Process Documents" width="90" x="246" y="30"> <parameter key="vector_creation" value="Binary Term Occurrences"/> <process expanded="true" height="536" width="950"> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
