No way to free memory?
Hello,
Currently my setup is
Read arff -> Nominal to Binominal -> FPGrowth
After 1 run, my memory is full (6Gig ram), but I get a clean result. If I run this again, I soon get an outOfMemory expception.
Now my question is: How can I clear the memory after a process execution? I don't want to restart RM every time.
Second question:
In FPGrowth I only want itemsets which have attributes with the prefix "proc" in it. When I type proc[A-Za-z0-9]+ in the "only include" bar, I don't get what I wanted. I still get a lot of itemsets that don't include those item(s). In fact I only want association rules with those items in the consequent, how can I do that?
Thank you in advance
Second question:
1 - 1 of
11
I repetitively grind frequent item sets in a loop, and keep the memory under control by 'materialising' the data, doing the jobbies and then explicitly scrubbing memory, like this... I think you are right to say that regex pattern finding does not apply in the FPGrowth 'must contain' parameter, you may well have to roll your own extension for that, as I did for FIS grinding on a CUDA card. What a treat!
Have fun!
