<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input> <location>FX Av(C) Weekly</location> <location>Pre-Processed FX</location> </input> <output> <location>PnP</location> </output> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="362" width="768"> <operator activated="true" class="set_macro" compatibility="5.2.003" expanded="true" height="76" name="Set Macro" width="90" x="179" y="165"> <description>This is the root string that will be matched against each pair. Leave as "." for all pairs.("."==.)</description> <parameter key="macro" value="sym"/> <parameter key="value" value="."/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.003" expanded="true" height="60" name="Forall Symbols" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value=".*%{sym}.*"/> <parameter key="use_except_expression" value="true"/> <parameter key="except_regular_expression" value="DateTime|NEXT"/> <parameter key="value_type" value="polynominal"/> <process expanded="true" height="347" width="821"> <operator activated="true" class="materialize_data" compatibility="5.2.003" expanded="true" height="76" name="Materialize Data" width="90" x="112" y="30"/> <operator activated="true" class="paracuda:Peek" compatibility="1.1.001" expanded="true" height="60" name="Peek" width="90" x="246" y="30"> <parameter key="source_att" value="%{loop_attribute}"/> </operator> <operator activated="true" class="loop_values" compatibility="5.2.003" expanded="true" height="76" name="Foreach Period" width="90" x="380" y="30"> <parameter key="attribute" value="DateTime"/> <process expanded="true" height="237" width="500"> <operator activated="true" class="filter_examples" compatibility="5.2.003" expanded="true" height="76" name="Filter timeslots" width="90" x="112" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="DateTime=%{loop_value}"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.003" expanded="true" height="76" name="Using Cues" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="value_type" value="binominal"/> <process expanded="true" height="371" width="567"> <operator activated="true" class="paracuda:Associator" compatibility="1.1.001" expanded="true" height="76" name="Associator" width="90" x="112" y="30"/> <operator activated="true" class="log" compatibility="5.2.003" expanded="true" height="76" name="Store Result" width="90" x="313" y="30"> <list key="log"> <parameter key="Period" value="operator.Foreach Period.value.current_value"/> <parameter key="Symbol" value="operator.Forall Symbols.value.feature_name"/> <parameter key="Label_Sets" value="operator.Associator.value.bean_count"/> </list> </operator> <connect from_port="exampleSet" to_op="Associator" to_port="example set"/> <connect from_op="Associator" from_port="example set" to_op="Store Result" to_port="through 1"/> <connect from_op="Store Result" from_port="through 1" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Filter timeslots" to_port="example set input"/> <connect from_op="Filter timeslots" from_port="example set output" to_op="Using Cues" to_port="example set"/> <connect from_op="Using Cues" from_port="example set" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="free_memory" compatibility="5.2.003" expanded="true" height="76" name="Free Memory" width="90" x="581" y="30"/> <connect from_port="example set" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Materialize Data" from_port="example set output" to_op="Peek" to_port="example set"/> <connect from_op="Peek" from_port="example set" to_op="Foreach Period" to_port="example set"/> <connect from_op="Foreach Period" from_port="out 1" to_op="Free Memory" to_port="through 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="108"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.2.003" expanded="true" height="76" name="Av.Wk. Cues" width="90" x="447" y="165"> <process expanded="true" height="269" width="748"> <operator activated="true" class="log_to_data" compatibility="5.2.003" expanded="true" height="94" name="Convert Log" width="90" x="112" y="30"/> <operator activated="true" class="pivot" compatibility="5.2.003" expanded="true" height="76" name="Table View" width="90" x="246" y="30"> <parameter key="group_attribute" value="Period"/> <parameter key="index_attribute" value="Symbol"/> <parameter key="consider_weights" value="false"/> <parameter key="skip_constant_attributes" value="false"/> </operator> <operator activated="true" class="guess_types" compatibility="5.2.003" expanded="true" height="76" name="Guess Types" width="90" x="380" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="Period|Label.*"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.2.003" expanded="true" height="76" name="Rename by Replacing" width="90" x="514" y="30"> <parameter key="replace_what" value="\W+"/> </operator> <connect from_port="in 1" to_op="Convert Log" to_port="through 1"/> <connect from_op="Convert Log" from_port="exampleSet" to_op="Table View" to_port="example set input"/> <connect from_op="Table View" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.2.003" expanded="true" height="76" name="Cues V Closes" width="90" x="514" y="30"> <parameter key="remove_double_attributes" value="false"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="Period" value="Period"/> </list> </operator> <connect from_port="input 1" to_op="Cues V Closes" to_port="left"/> <connect from_port="input 2" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Forall Symbols" to_port="example set"/> <connect from_op="Forall Symbols" from_port="example set" to_op="Av.Wk. Cues" to_port="in 1"/> <connect from_op="Av.Wk. Cues" from_port="out 1" to_op="Cues V Closes" to_port="right"/> <connect from_op="Cues V Closes" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
