"what's wrong with my Generate Attribute?"
I get Syntax Error:
An operator failed to generate a macro, attribute or other object which is calculated on the fly.
My XML text entries (in InstitutionName or macroGoogleQuery) have CRLFs in them - could that be the problem? How do I filter out the \r and \n's?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<parameter key="logverbosity" value="all"/>
<parameter key="logfile" value="C:\Users\charper\Documents\Rapid-I\GetPagesLog.txt"/>
<parameter key="resultfile" value="C:\Users\charper\Documents\Rapid-I\ExampleSet1.csv"/>
<parameter key="encoding" value="UTF-8"/>
<process expanded="true" height="428" width="547">
<operator activated="true" class="read_xml" compatibility="5.2.003" expanded="true" height="60" name="Read XML" width="90" x="45" y="30">
<parameter key="file" value="C:\Users\charper\Documents\ALiNBUS\libwebcatsout-20120303.xml"/>
<parameter key="xpath_for_examples" value="//html/Institution"/>
<enumeration key="xpaths_for_attributes">
<parameter key="xpath_for_attribute" value="InstitutionName[1]/text()"/>
<parameter key="xpath_for_attribute" value="Row[1]/attribute::rownum"/>
<parameter key="xpath_for_attribute" value="LibraryName[1]/text()"/>
<parameter key="xpath_for_attribute" value="Location[1]/text()"/>
<parameter key="xpath_for_attribute" value="Consortium[1]/text()"/>
<parameter key="xpath_for_attribute" value="website[1]/text()"/>
<parameter key="xpath_for_attribute" value="catalog[1]/text()"/>
<parameter key="xpath_for_attribute" value="CatalogVendor[1]/text()"/>
</enumeration>
<list key="namespaces">
<parameter key="xsi" value="http://www.w3.org/2001/XMLSchema-instance"/>
</list>
<parameter key="use_default_namespace" value="false"/>
<list key="annotations"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="InstitutionName[1]/text().true.polynominal.attribute"/>
<parameter key="1" value="Row[1]/attribute::rownum.true.integer.attribute"/>
<parameter key="2" value="LibraryName[1]/text().true.text.attribute"/>
<parameter key="3" value="Location[1]/text().true.polynominal.attribute"/>
<parameter key="4" value="Consortium[1]/text().true.polynominal.attribute"/>
<parameter key="5" value="website[1]/text().true.text.attribute"/>
<parameter key="6" value="catalog[1]/text().true.text.attribute"/>
<parameter key="7" value="CatalogVendor[1]/text().true.polynominal.attribute"/>
</list>
</operator>
<operator activated="true" class="loop_examples" compatibility="5.2.003" expanded="true" height="76" name="Loop Examples" width="90" x="179" y="30">
<process expanded="true" height="446" width="557">
<operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30">
<parameter key="macro" value="macroGoogleQuery"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="InstitutionName[1]/text()"/>
<parameter key="example_index" value="1"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="210">
<list key="function_descriptions">
<parameter key="urlGoogleQuery" value=""http://www.google.com/search?q=" + replaceAll("%{macroGoogleQuery}","\n","+")"/>
</list>
<parameter key="use_standard_constants" value="false"/>
</operator>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="example set"/>
<portSpacing port="source_example set" spacing="0"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
</operator>
<connect from_op="Read XML" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</enumeration>
</list>
</list>
</operator>
</operator>
</list>
</operator>
</process>
</operator>
</process>
</operator>
</process>
1 - 3 of
31
So here's a real newbie question - I could see how I could make the value of an attribute available for use in the Generate Attribute operator if I made a macro, but can I call the value of an attribute directly in my Generate Attribute operator? Can't I set the value of the new attribute to %{InstitutionName.value} if InstitutionName is the name of one of my row attributes?
It might also be that your attribute names contain brackets; normally this doesn't matter, but in regex it does, you have to be very careful about escaping special characters, and avoiding others. Here's and example which produces your error I know this from bitter, and recent, experience, here's some code for my RapidAnalytics server, where I read in some attributes with brackets, and scale one column against another. Don't try and run it, just check out the attribute generator, and in particular the regex... Here the new attribute's name comes from a macro, and its value comes from another attribute, itself named using a macro, multiplied by some other macros, themselves named according to a macro. So macros and attributes in total confusion, and the regex parser says it's illegal. What a treat, but guess what, it works...
Good luck with your endeavours.
