I get Syntax Error:
An operator failed to generate a macro, attribute or other object which is calculated on the fly.
My XML text entries (in InstitutionName or macroGoogleQuery) have CRLFs in them - could that be the problem? How do I filter out the \r and \n's?
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<parameter key="logverbosity" value="all"/>
<parameter key="logfile" value="C:\Users\charper\Documents\Rapid-I\GetPagesLog.txt"/>
<parameter key="resultfile" value="C:\Users\charper\Documents\Rapid-I\ExampleSet1.csv"/>
<parameter key="encoding" value="UTF-8"/>
<process expanded="true" height="428" width="547">
<operator activated="true" class="read_xml" compatibility="5.2.003" expanded="true" height="60" name="Read XML" width="90" x="45" y="30">
<parameter key="file" value="C:\Users\charper\Documents\ALiNBUS\libwebcatsout-20120303.xml"/>
<parameter key="xpath_for_examples" value="//html/Institution"/>
<enumeration key="xpaths_for_attributes">
<parameter key="xpath_for_attribute" value="InstitutionName[1]/text()"/>
<parameter key="xpath_for_attribute" value="Row[1]/attribute::rownum"/>
<parameter key="xpath_for_attribute" value="LibraryName[1]/text()"/>
<parameter key="xpath_for_attribute" value="Location[1]/text()"/>
<parameter key="xpath_for_attribute" value="Consortium[1]/text()"/>
<parameter key="xpath_for_attribute" value="website[1]/text()"/>
<parameter key="xpath_for_attribute" value="catalog[1]/text()"/>
<parameter key="xpath_for_attribute" value="CatalogVendor[1]/text()"/>
</enumeration>
<list key="namespaces">
<parameter key="xsi" value="
http://www.w3.org/2001/XMLSchema-instance"/>
</list>
<parameter key="use_default_namespace" value="false"/>
<list key="annotations"/>
<parameter key="0" value="InstitutionName[1]/text().true.polynominal.attribute"/>
<parameter key="1" value="Row[1]/attribute::rownum.true.integer.attribute"/>
<parameter key="2" value="LibraryName[1]/text().true.text.attribute"/>
<parameter key="3" value="Location[1]/text().true.polynominal.attribute"/>
<parameter key="4" value="Consortium[1]/text().true.polynominal.attribute"/>
<parameter key="5" value="website[1]/text().true.text.attribute"/>
<parameter key="6" value="catalog[1]/text().true.text.attribute"/>
<parameter key="7" value="CatalogVendor[1]/text().true.polynominal.attribute"/>
</list>
<operator activated="true" class="loop_examples" compatibility="5.2.003" expanded="true" height="76" name="Loop Examples" width="90" x="179" y="30">
<process expanded="true" height="446" width="557">
<operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30">
<parameter key="macro" value="macroGoogleQuery"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="InstitutionName[1]/text()"/>
<parameter key="example_index" value="1"/>
<operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes" width="90" x="380" y="210">
<parameter key="urlGoogleQuery" value=""
http://www.google.com/search?q=" + replaceAll("%{macroGoogleQuery}","\n","+")"/>
</list>
<parameter key="use_standard_constants" value="false"/>
<connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="example set"/>
<portSpacing port="sink_example set" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<connect from_op="Read XML" from_port="output" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="example set" to_port="result 1"/>
</process>
</process>
