Editing single value in a repository dataset
I have a feeling that there is a really simple answer to this that I am missing. I have imported a large spreadsheet into the local RM 5.2 repository, and spent a while labeling and typing everything during the import process. Now that I want to start to work with it I find that there is an erroneous value in the middle of the data set. I would rather not have to change the value in the spreadsheet and go through the import process again, is there a simple way for me to change the one "cell" from 47 to a 3? Am I missing some sort of basic data editing functionality, or am I just lazy? Thanks, Chris
1 - 1 of
11
there are two possibilities. First you can buy the RapidMiner Enterprise Edition where you can edit values of an example set without using an operator.
Or you can use the "Set Data" Operator. Here is an example: Best,
Nils
