how to use rapidminer's DatabaseDataReader in java 1.6
how to use rapidminer's databaseReader(like db access) in java 1.6
SDK VERSION:RapidMiner 5.2
can anyone give me some demos
I need a demo like this:read from Microsoft Access,use a train method,then predit
Operator trainInPutOpr = null;
try {
trainInPutOpr = OperatorService.createOperator(DatabaseDataReader.class);
} catch (OperatorCreationException e1) {
// TODO Auto-generated catch block
e1.printStackTrace();
trainInPutOpr.setParameter(DatabaseHandler.PARAMETER_CONNECTION, "jdbc:odbc:tcm");//????????????????
Thanks!
JZB
try {
Thanks!
JZB
1 - 3 of
31
thanks for your reply!I am now coding as your recommention.Could you give more vedios or design docs about rapidminer.You know,we can't broswe youtube easily in china.When can rapidminer have an edition of Chinese,and what can I do for it.Thank u very muck.My english is so poor. :P
Marco Boeck wrote:
Hi,
why don't you use the recommended way (execute RapidMiner processes instead of building one yourself)? There are more than enough examples in this forum for you to find.
Creating the whole proecss yourself is error-prone and tedious, whereas executing a previously created RapidMiner process is easy and pretty straight-forward
Regards,
Marco
Hi,
you might want to check out these pages:
Videos: http://rapid-i.com/content/view/189/212/lang,en/#quick_tour
Manuals: http://rapid-i.com/content/view/36/210/lang,en/
Regarding the chinese translation: I do now know when and if there will be one available, however you could contact "contact [at) rapid-i.com" and try to arrange something
Regards,
Marco
Regards,
Marco
Regards,
Marco
