"[PARTIALLY SOLVED] Problem Running RapidAnalytics on Amazon EC2"
Hello,
I am trying to set up RapidMiner and RapidAnalytics on an amazon ec2 instance. Everything went smooth during the installation of both, RapidMiner runs perfect, but when I try to start the RapidAnalytics server with the following command:
This is the last info the log gives me before killing the start
Thanks a lot!
sudo sh run.shI get the usual log data and it halts on a specific line (listed below) then I get a
Killedline
Any tip on what can be the problem as there is no error message or anything.
18:42:15,127 INFO [DefaultListableBeanFactory] Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1f7b41b: defining beans [cxf,org.apache.cxf.bus.spring.BusApplicationListener,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,
org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,
org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,
org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,
org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,
org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,
org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,
org.apache.cxf.service.factory.FactoryBeanListenerManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,
org.apache.cxf.binding.http.HttpBindingFactory,org.apache.cxf.binding.object.ObjectBindingFactory,
org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,
org.apache.cxf.binding.soap.customEditorConfigurer,org.apache.cxf.binding.xml.XMLBindingFactory,
org.apache.cxf.jaxws.context.WebServiceContextResourceResolver,org.apache.cxf.jaxws.context.WebServiceContextImpl,
org.apache.cxf.management.InstrumentationManager,org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder,
org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder,org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider,
org.apache.cxf.transport.http.ClientOnlyHTTPTransportFactory,
org.apache.cxf.transport.jms.JMSTransportFactory,org.apache.cxf.transport.local.LocalTransportFactory,
org.apache.cxf.ws.addressing.policy.AddressingAssertionBuilder,org.apache.cxf.ws.addressing.policy.AddressingPolicyInterceptorProvider,
org.apache.cxf.ws.addressing.policy.UsingAddressingAssertionBuilder,org.apache.cxf.ws.policy.AssertionBuilderRegistry,
org.apache.cxf.ws.policy.PolicyInterceptorProviderRegistry,org.apache.cxf.ws.policy.attachment.external.DomainExpressionBuilderRegistry,
org.apache.cxf.ws.policy.attachment.external.EndpointReferenceDomainExpressionBuilder,org.apache.cxf.ws.policy.PolicyBuilder,
org.apache.cxf.ws.policy.PolicyEngine,org.apache.cxf.ws.policy.attachment.wsdl11.Wsdl11AttachmentPolicyProvider,
org.apache.cxf.ws.policy.attachment.ServiceModelPolicyProvider,org.apache.cxf.ws.policy.mtom.MTOMAssertionBuilder,
org.apache.cxf.ws.policy.mtom.MTOMPolicyInterceptorProvider,org.apache.cxf.ws.rm.RMManager,
org.apache.cxf.ws.rm.policy.RMPolicyInterceptorProvider,org.apache.cxf.ws.rm.policy.RMAssertionBuilder,
org.apache.cxf.ws.security.policy.WSSecurityPolicyLoader,org.jboss.wsf.stack.cxf.addons.transports.httpserver.HttpServerTransportFactory];
root of factory hierarchy
Killed
Thanks a lot!
It looks like the small linux ubuntu instance with 1.7GB of memory is not enough to start the RapidAnalytics server (though I am not sure why its not enough) but I tried running the same image into a medium instance and it worked fine so I am assuming there is an issue with the RAM.
This setup increases my costs, so I will use it know to get out of the hurry while I try to understand why the small instance is not working.
