🎉Community Raffle - Win $25
Join and Win
Correlation - need help getting started
RCL1User: "RCL1"
New Altair Community Member
Updated by Jocelyn
Folks- I've just started using Rapid Miner and am trying to calculate a correlation coefficient as a first test.
My data set includes three columns, the first is the key, so the role is set to "id". The second column would be my dependent variable, so I set role to "label". Finally, the third column I set to "regular".
In the Designer, I piped a "retrieve" of the data to a "Correlation Matrix" operator.
When I run the process, the results perspective does not show correlation in the Meta Data View. Under the Statistics column, it only shows avg = 1235 +/- 123, as well as a Range column.
Can anyone tell me how to get it to calculate and display a Pearson correlation coefficient?
Thanks,
RCL1
1 - 5 of 51
    RCL1User: "RCL1"
    OP
    Still trying to square what I'm reading in the manual with my test example. Re-imported the data:
    Four columns: IP ID (Integer, ID); Income (integer, weight); Expenditure (integer, attribute); WC QT (integer, attribute)
    Now when I pipe this data retrieve to the correlation matrix, I only get average and range for statistics under Meta Data View.
    Where do I calculate a correlation coefficient?
    Thanks,
    RL
    Hi, did you connect the mat output of Correlation Matrix to the process output? Please have a look at the process below. If that does not solve your problem, please attach your process setup as described in this thread: http://rapid-i.com/rapidforum/index.php/topic,4782.0.html
    Best,
    Marius
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.2.002">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process">
        <process expanded="true" height="638" width="716">
          <operator activated="true" class="generate_data" compatibility="5.2.002" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30">
            <parameter key="target_function" value="random classification"/>
          </operator>
          <operator activated="true" class="correlation_matrix" compatibility="5.2.002" expanded="true" height="94" name="Correlation Matrix" width="90" x="313" y="30"/>
          <connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
          <connect from_op="Correlation Matrix" from_port="example set" to_port="result 1"/>
          <connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    RCL1User: "RCL1"
    OP
    Ok, I took a look. Other than some style differences I'm not seeing any glaring problems.
    This is my process:
    <process version="5.2.000">
     <context>
       <input>
         <location>//RapdMinerNewLocalRepository/CorrTest</location>
       </input>
       <output/>
       <macros/>
     </context>
     <operator activated="true" class="process" compatibility="5.2.000"
       <process expanded="true" height="435" width="413">
         <operator activated="true" class="retrieve"
    compatibility="5.2.000" expanded="true" height="60" name="Retrieve"
    width="90" x="87" y="237">
           <parameter key="repository_entry" value="corrTest2"/>
         </operator>
    compatibility="5.2.000" expanded="true" height="94" name="Correlation
    Matrix" width="90" x="338" y="221">
           <parameter key="squared_correlation" value="true"/>
         </operator>
         <connect from_op="Retrieve" from_port="output"
         <portSpacing port="source_input 1" spacing="54"/>
       </process>
     </operator>
    </process>
    RCL1User: "RCL1"
    OP
    I changed port spacing from 54 to 0 on result 2.
    I'm getting a pairwise table now...
    The port spacing should not influence the results at all, it's just for the visualization of the process.
    Is that what you want?
