Correlation - need help getting started
Folks- I've just started using Rapid Miner and am trying to calculate a correlation coefficient as a first test.
My data set includes three columns, the first is the key, so the role is set to "id". The second column would be my dependent variable, so I set role to "label". Finally, the third column I set to "regular".
In the Designer, I piped a "retrieve" of the data to a "Correlation Matrix" operator.
When I run the process, the results perspective does not show correlation in the Meta Data View. Under the Statistics column, it only shows avg = 1235 +/- 123, as well as a Range column.
Can anyone tell me how to get it to calculate and display a Pearson correlation coefficient?
Thanks,
RCL1
Thanks,
RCL1
1 - 5 of
51
Hi, did you connect the mat output of Correlation Matrix to the process output? Please have a look at the process below. If that does not solve your problem, please attach your process setup as described in this thread: http://rapid-i.com/rapidforum/index.php/topic,4782.0.html
Best,
Marius
Best,
Marius
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process">
<process expanded="true" height="638" width="716">
<operator activated="true" class="generate_data" compatibility="5.2.002" expanded="true" height="60" name="Generate Data" width="90" x="112" y="30">
<parameter key="target_function" value="random classification"/>
</operator>
<operator activated="true" class="correlation_matrix" compatibility="5.2.002" expanded="true" height="94" name="Correlation Matrix" width="90" x="313" y="30"/>
<connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="example set" to_port="result 1"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
Ok, I took a look. Other than some style differences I'm not seeing any glaring problems.
This is my process:
This is my process:
<process version="5.2.000">
<context>
<input>
<location>//RapdMinerNewLocalRepository/CorrTest</location>
</input>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.000"
<process expanded="true" height="435" width="413">
<operator activated="true" class="retrieve"
compatibility="5.2.000" expanded="true" height="60" name="Retrieve"
width="90" x="87" y="237">
<parameter key="repository_entry" value="corrTest2"/>
</operator>
compatibility="5.2.000" expanded="true" height="94" name="Correlation
Matrix" width="90" x="338" y="221">
<parameter key="squared_correlation" value="true"/>
</operator>
<connect from_op="Retrieve" from_port="output"
<portSpacing port="source_input 1" spacing="54"/>
</process>
</operator>
</process>
Four columns: IP ID (Integer, ID); Income (integer, weight); Expenditure (integer, attribute); WC QT (integer, attribute)
Now when I pipe this data retrieve to the correlation matrix, I only get average and range for statistics under Meta Data View.
Where do I calculate a correlation coefficient?
Thanks,
RL
