🎉Community Raffle - Win $25
Join and Win
Correlation - need help getting started
User: "RCL1"
New Altair Community Member
Updated by Jocelyn
Folks- I've just started using Rapid Miner and am trying to calculate a correlation coefficient as a first test.
My data set includes three columns, the first is the key, so the role is set to "id". The second column would be my dependent variable, so I set role to "label". Finally, the third column I set to "regular".
In the Designer, I piped a "retrieve" of the data to a "Correlation Matrix" operator.
When I run the process, the results perspective does not show correlation in the Meta Data View. Under the Statistics column, it only shows avg = 1235 +/- 123, as well as a Range column.
Can anyone tell me how to get it to calculate and display a Pearson correlation coefficient?
Thanks,
RCL1
