Loading multiple pdf files
I am trying to load a corpus of several pdf-files into RM. I selected 'Process documents from Files' from the text processing menu and selected the directory with the pdf-files. But when I run this process, it gives me the following error message :
Feb 28, 2012 2:30:04 AM SEVERE: Process failed: operator cannot be executed. Check the log messages...
Feb 28, 2012 2:30:04 AM SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
==> +- Process Documents from Files[1] (Process Documents from Files)
subprocess 'Vector Creation'
Feb 28, 2012 2:30:04 AM SEVERE: java.lang.ArrayIndexOutOfBoundsException
Can you please help?
-Stephan
-Stephan
