"Correlation Matrix Operator - which kind of correlation coefficient?"
Hi,
i was wondering which kind of correlation coefficient is calculated by the "Correlation Matrix Operator"?
Since I have a wide variety of factors and factor distributions (many of which are not Gaussian), the Spearman correlation is preferred to the more familiar Pearson correlation (as Pearson correlation assumes the variables are Gaussian).
Best regards,
Matthias
Best regards,
Matthias
1 - 4 of
41
Hi there,
My question is a follow-up on this issue so I am replying here instead of opening a new post.
You mention the Correlation Matrix operator uses the Pearson correlation coefficient.
I have built a Correlation matrix for data which has a mixture of Nominal and Numeric variables,
and I seem to be getting a very decent matrix. For numerical pairs I assume it is using Pearson like you said, but what
about the other pairs:
1. How are the correlation coefficients for numeric vs. nominal (non-dichotomous) calculated? (is some specific point multiserial coefficient used?!)
2. How are the correlation coefficients for nominal (non-dichotomous) vs. nominal (non-dichotomous) calculated? (does it use Pearson's C, Kramer;'s V!?)
It would be very helpful to know this, and any relevent references.
Thanks in advance,
Sharper
Thanks in advance,
Sharper
the operator "Correlation Matrix" uses the Pearson correlation coefficient. If you think other coefficients like Spearman should be part of the operator in the next release please use the feature request tracker (http://bugs.rapid-i.com/) and leave a short note.
Cheers,
Helge
