create time sensor in radioss - problem
Hi,
I have a problem. I defined a spring type 4 with a force - displacement curve, where the spring ends move together. It works very well. Now I want to create a time-sensor, which should deactivate the spring after a time t=0.015 s from the beginning of the simulation. Could someone help me, please?
I have already defined a sensor type 0 with tdelay = 0.015 s and have referenced to the spring with lflag = 1, but it does not work.
I am using hyperworks 14.0 with radioss 14.0 as well. You can find my simple example model below.
