Relaxing DOFs
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
I have a problem regarding the modelling of a ball joint. I would like to relax the three rotations of a node shared by two beam elements but couldn't find out how.
If I try to use the command 'joint' then I have to solve the simulation as a multibody dynamic problem and that looks more complicated as I need to set up more control cards like MBSIM and set up other options which I do not understand.
What's the best strategy to solve my problem?
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited August 2015
    Hi
    two beams connect together with full 6 dofs
    if you want to release some dofs, just update 'pin flag'
    enter panel 1d>bar>update to do this
    and be careful that these 'pin flag' dofs are in beam coordinate system, not basic system
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited January 2019
    Hi
    Hi tinh, can I use the same procedure in radioss ??
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited January 2019
    Multibody Dynamics Simulation is only available with OptiStruct.So Radioss will not work here.
Welcome!
Welcome!
