I have a problem regarding the modelling of a ball joint. I would like to relax the three rotations of a node shared by two beam elements but couldn't find out how.
If I try to use the command 'joint' then I have to solve the simulation as a multibody dynamic problem and that looks more complicated as I need to set up more control cards like MBSIM and set up other options which I do not understand.
What's the best strategy to solve my problem?
