I've been playing with Ensemble Models lately. When I try to use the "Meta" operators from Weka (say for instance W-Vote) I don't see inside the operators the input or output ports/connectors. Am I missing something basic?
Thanks in advance for any help
Ernesto
Weka Ensemble Models work with Weka classifiers only. You dont have to connect the classifiers, they will get the input automaticly. Here is an example: Regards,
Nils
