<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.014"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process"> <process expanded="true" height="579" width="708"> <operator activated="true" class="retrieve" compatibility="5.1.014" expanded="true" height="60" name="Retrieve" width="90" x="150" y="176"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="weka:W-Vote" compatibility="5.1.001" expanded="true" height="76" name="W-Vote" width="90" x="313" y="165"> <process expanded="true" height="639" width="950"> <operator activated="true" class="weka:W-KStar" compatibility="5.1.001" expanded="true" height="76" name="W-KStar" width="90" x="363" y="216"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="W-Vote" to_port="training set"/> <connect from_op="W-Vote" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
