[SOLVED] Using file names
Hi there,
After crawling various URLs I end up with a bunch of files and their names are based on some URL attributes.
Now, when I want to process those documents I'd like to to extract their name so I can use it in my final results set. Is there any way I can do that? Maybe some Macro inside Process Documents?
Thanks in advance for your answers.
1 - 3 of
31
after application of the Process Documents from File operator the resulting example set contains the filename and path as special attributes. Maybe you can get along with that?
Kind regards,
Marius
