In a random frequency response analysis, the input is in PSD in (m/s2)2/Hz and RMS value in m/s2. I need to perform a random vibration analysis in Hypermesh using Optistruct. How we should input PSD and RMS values. What load collectors/cards should we use?.
Next question is regarding units, if Im using mm,Tonne,Newton units. Then how should i convert the PSD data in (m/s2)2/Hz to compatible units.
