Community & Support
Learn
Marketplace
Discussions
Categories
Discussions
General
Platform
Academic
Partner
Regional
User Groups
Documentation
Events
Altair Exchange
Share or Download Projects
Resources
News & Instructions
Programs
YouTube
Employee Resources
This tab can be seen by employees only. Please do not share these resources externally.
Groups
Join a User Group
Support
Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
[SOLVED] Assigning value types
steinar
Hi
I'm just beginning with RapidMiner, but have gone through some tutorials. None seem to address this problem.
The data set I'm working with is huge and has over 1000 attributes. When I import it from a csv file, RM guesses the attribute types. The majority of my attributes should be binomial, but RM thinks they are integers. Is there a way to assign them all as binomial at once without having to click on each column and choose binomial?
Also, is there a way to change these definitions once the data has been stored in a repository?
Best regards,
Steinar
AI Studio
Accepted answers
All comments
MariusHelf
Hi Steinar,
I currently know of no possibility to automatically assign types to the attributes in the Read CSV operator, which are different to those guessed by RapidMiner. But you can use the Parse Numbers operator to convert all or some nominal attributes to numbers.
Cheers,
Marius
steinar
Thank you. I guess I'll just have to manually click then. It only takes me about half an hour for each set...
I was hoping there was something like in RDS in which you can define the attributes in your spreadsheet program and then just define the row like you do with name and unit in RM.
MariusHelf
Sorry, I read something wrong in your first post. Maybe the Numerical to Binominal operator might help you. Just have a look in the Data Transformation group in the operator tree view.
It is currently not possible to add the attribute type as annotation. Maybe this could be a useful feature for the future.
Regards,
Marius
steinar
The operator you pointed towards does work for this, but more importantly it led me to understand that binomial data in RM is True/False, not 1/0. All I had to do was replace all instances of "1" with "true" in excel and then RM identified the data correctly as binomial.
Thanks, now I can focus on my next problems.
MariusHelf
Basically, a binominal attribute in RapidMiner is every nominal attribute with exactly two values, no matter if they are 0/1, true/false or cats/dogs. The problem is that the csv parser assumes numerical values if it sees numerical input like 0/1.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
