<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="605" width="692"> <operator activated="true" class="web:crawl_web" compatibility="5.1.002" expanded="true" height="60" name="Crawl Web" width="90" x="45" y="30"> <parameter key="url" value="http://www.asklaila.com/search/Bangalore/-/shopping malls/?searchNearby=false&amp;ac=true"/> <list key="crawling_rules"> <parameter key="follow_link_with_matching_text" value=".*Shopping Malls.*"/> </list> <parameter key="write_pages_into_files" value="false"/> <parameter key="add_pages_as_attribute" value="true"/> <parameter key="output_dir" value="C:\Documents and Settings\Sudheendra\Desktop\b"/> <parameter key="extension" value="html"/> <parameter key="max_pages" value="4"/> <parameter key="user_agent" value="Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.2; .NET CLR 1.1.4322)"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="30"> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="607" width="763"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.002" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Crawl Web" from_port="Example Set" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
