which precondition should I add?
User: "gaoxiaolei"
New Altair Community Member
Updated by Jocelyn
Hi, everyone.
I developed a operator. This operator can only deal with exampleset has two attributes. I do not konw which precondition should I add to this operator. Could you help me?
Thanks.
gaoxiaolei
1 - 3 of 31
    User: "StaryVena"
    Hi,
    if I understand what you want, it should looks like this:
    inputPort.addPrecondition(new SimplePrecondition(inputPort, new MetaData(
    ExampleSet.class)));
    It doesn't matter how many attributes ExampleSet have.
    User: "gaoxiaolei"
    OP
    StaryVena wrote:
    Hi,
    Hi, thanks. But my opeator can only cope with exampleset which has only two attributes.
    I want this: if a exampleset with more than two attributes, and it connect to my opeator, there should be a error appeard.
    Hi,
    there are a couple of ways to achieve this, for example you can use the already mentioned SimplePrecondition class:
    inputPort.addPrecondition(new SimplePrecondition(inputPort, new MetaData(ExampleSet.class), true) {
    @Override
    /** Override this method to make additional checks. The default implementation does nothing. */
    public void makeAdditionalChecks(MetaData received) {
    if (((ExampleSetMetaData)received).getAllAttributes().size() != 2) {
    inputPort.addError(new SimpleMetaDataError(Severity.ERROR, inputPort, "I18N.key"));
    Regards,
    Marco
