Carbon Fibre Tows Simulation in Hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear Community,
my name is Lennart, I am a composites engineering student from Germany and I have started working with Optistruct/Hypermesh full-time since a few weeks. I am trying to get ahold of composite optimisation.
Optistruct is only partially able to compute composite parts. it appears that I am very limited in the design of more complex parts. What I am looking for in particular is a way to not only design plies in flat structures, but rather tows and roving in 3D parts, for example a scaffold of a crane or similar.
I AM able to model 3D composite structures by designing surfaces which come close to the 3D part and apply a laminate as a workaround.
As a first step towards 3D composite optimisation, I would like to have a workaround solution for working with single tows. For example if I have a 2D circular part, let's say a simple ring.
If I apply a tensile force (with a bolt or similar), the ideal optimisation result for a minimum displacement of the circle geometry would be a 'ring' of carbon fibres. However I am not quite sure how to get this result in Optistruct. This is not possible when the program only 'thinks' with plies.
is there any way how I could achieve this result with the given Optistruct possibilites? Any way to 'cheat' and work with single fibre tows instead of plies?
Any help would be greatly apprechiated.
Regards,
Lenny
1 - 14 of 141
    Altair Employee
    OP
    Hi @Lenny
    What type of optimization are you interested in?
    How are you applying the forces in the circular ring?
    Is it on the circumference or at the middle?
    Altair Employee
    OP
    I am interested in finding the optimum ply lay-up for my complex CFRP part and I am trying to understand how to make Hypermesh/Optistruct do what I want it to do by starting off with simple geometries and working my way up.
    Ultimately, I want my to optimize the topology of my part and have carbon fibres places ideally for all load cases.
    As for the ring geometry:
    I am applying the force on the center of a Rigid Body Element (RBE2), which connects its centre node to all the nodes on the inner 'line' of the ring.
    So I am applying the force at the middle.
    Altair Employee
    OP
    OK thanks. I will try to reproduce the a similar situation. Just another question. Is the force normal to ply surface?
    Altair Employee
    OP
    No, the force is parallel to the ply surface, thus the force will only deform the ring and not bend it. The surface part (ring) and the force are parallel to each other in on plane.
    Thank you for your effort! :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Altair Employee
    OP
    Hello,
    If you don't mind me asking, have you come to a conclusion? :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Altair Employee
    OP
    @Lenny
    I am working with free size instead of topology just to check the pattern. So far no success..
    Let me explain what I have done so far...
    1) 4 layers of plies
    2) Applied a force in the middle on a RBE2
    3) Cyclic pattern constrain used
    Let me know if this is what you are doing...
    Altair Employee
    OP
    This is exactly what I am looking for.
    I used multiple plies with steps of 5°, to get a more accurate result, but this should work just as fine.
    The optimum result of the fibre orientation optimisation should be forming a 'ring' within the circular part, which, in reality, is the ideal fibre positioning.
    However as mentioned, I am unsure how to achieve the expected optimum result. I am unsure if Optistruct is able to compute this case with realistic results.
    Altair Employee
    OP
    @Lenny
    I am playing with some constraints. I will let you soon if I see any success.
    Altair Employee
    OP
    Hi @Lenny
    Something like this is what you looking for?
    Altair Employee
    OP
    Oh my god yes, this is exactly what I expect the result to be!
    Would you mind sharing with me how exactly you achieved this? :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Thank you so so much!
    Altair Employee
    OP
    @Lenny
    I applied a moment around the axis of disc. With load perpendicular to axis was not helpful at all.  I attached the model file.
    Altair Employee
    OP
    Wow! This is exactly what I was looking for!
    if you don't mind me asking, how did you manage to make the 0° ply direction go in a  circular manner?
    I can only get it to point into one global direction (x,y,z), but having the ply/material direction go in circles around the part should come quite handy!
    Your support is amazing, thank you so much.
    Altair Employee
    OP
    @Lenny
    Create a cylindrical coordinate system. I assumed 0deg in the direction of radius and anything perpendicular will be 90deg which lays fiber in circular manner.
    Altair Employee
    OP
    Perfect, exactly what I needed.
    Thank you so much! :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
