When I launch a simulation on Inspire Form it progresses up to 50%, but then stays at this point indefinitely. There is no error message and on the run folder the CurRunStatus.xml file is the only one to be updated.
You can check the results till this time step by clicking on the run and select view now, to check if the part forming without any issues or the blank mesh got distorted and resulting in higher thinning%. If the blank is showing higher thinning %, then check the tools CAD and the setup again.
Hi,
Thanks and Regards,
Saurabh
