🎉Community Raffle - Win $25
Join and Win
"Save parameters and performance in Loop parameter"
User: "kix"
New Altair Community Member
Updated by Jocelyn
Hello everyone. I am trying to try out different parameters for an SVM model. I want to save the performances of different parameter settings (write out to a file). Is it possible? I can't get the parameters that I want to record. And also, what's the best way to bundle the parameter and the performance together? Thanks in advance.
1 - 3 of 31
    User: "Marco_Boeck"
    Hi,
    take a look at the sample processes provided with RapidMiner. Especially the folder //Smples/processes/06_Meta should be interesting.
    Regards,
    Marco
    User: "kix"
    OP
    Thanks. I had not looked in it. I still don't know how to do it, but I guess I can use several models instead of test it in a loop.
    User: "IngoRM"
    Hi,
    the "Log" operator is your solution, just log the parameter values together with the current performance while you perform a parameter optimization or iteration. Well, as Marco has said: Load the process "01_Parameter_Optimization" from the "Meta" directory in the preinstalled "Sample"-Repository. If you don't know what I am talking about, I would suggest reading the manual first...
    Cheers,
    Ingo
