Topology and lattice optimization results - CAD interpretation
Hello,
I would like to ask you about the software which you use for processing the results from OptiStruct topology optimization because OSSmooth does not provide CAD files good enough for manufacturing. Do you think that is good to make FEM reanalysis without surface remodeling? Does it provide valuable information about the structure? And how do you recommend working with lattice optimization? Because many of the optimized BEAM elements aren't 3D-printable. Is there any experienced workflow how to get a printable CAD file?
