Histogram Color
Hello,
i'am trying to plot some "histogram color's" under "example set" -->"plot view" with searching the Label Attribute, to compare it with any other attribute.
The comperisation of the attributes with each other worked until i changed the import file, which not realy differs from the other one which had worked to 100%!
Now the comperisation works only with some attributes not with all, what i cant unterstand...
Greetings
Greetings
1 - 7 of
71
I have now another question related to "histogram color" again!
Is it possible to order the both histogram colors wich are compared? Because one is smaller and behind the other one, which cant be seen clearly.
I dont like the possiblity with Opaqueness!
Is there a possibility to show the smaller one at the front and the big one behind?
Thank you,
Greetings
Thank you,
Greetings
@Ingo The problem seems to be that some of the nominal values have 0 items corresponding to it. Removing these unused attribute values has solved the problem.
Hi,
ah, thanks for pointing this out. If you like, please submit this as a bug at
http://bugs.rapid-i.com
This would help us to track this down for one of the next releases.
Cheers,
Ingo
Cheers,
Ingo
Cheers,
Ingo
