i'am trying to plot some "histogram color's" under "example set" -->"plot view" with searching the Label Attribute, to compare it with any other attribute.
The comperisation of the attributes with each other worked until i changed the import file, which not realy differs from the other one which had worked to 100%!
Now the comperisation works only with some attributes not with all, what i cant unterstand...
Greetings
