"Read CSV to example set"
Hi,
Just beginning RapidMiner experiment & having trouble with "Read CSV" operator.
I can output the data to res (and see the ExampleSet), but when other operators require an example set in input, no data is available. Is this a limitation of Read CSV or is there a way to make the data available as an example set ?
Regards.
Regards.
