"Reporting Extension: character encoding issue"
User: "jeszy"
New Altair Community Member
Updated by Jocelyn
Hello,
I would like to generate a PDF report on Linux. I have experienced
problems with the handling of non-Latin-1 characters, some of the
accented characters available in Latin-2 are missing from the
resulting PDF document. I tried to change the fonts in the Reporter
Settings dialog but it does not help.
Any idea how to solve the problem?
Best regards,
Peter
1 - 2 of 21
    User: "jeszy"
    OP
    The extension uses the excellent iText library to generate PDF
    documents. As I see, the character encoding is fixed to "WINANSI"
    in class com.rapidminer.report.PdfReportStream, that is a major
    limitation.
    Best regards,
    Peter
    User: "land"
    Hi Peter,
    do you have an Enterprise Edition? Then please send a ticket over the usual ticket system. Otherwise please post a feature request to out bugtracker. It's a really unnecessary restriction as I think the report in general is able to handle encodings. It seems to me, this code lines have been forgotten since a non standard way of defining encoding is used here by iText.
    Greetings,
    Sebastian
