🎉Community Raffle - Win $25
Join and Win
Get Subcase list and it's details in hyperworks desktop
raj_20928User: "raj_20928"
Altair Community Member
Updated by raj_20928
Hi all,
Good afternoon,
I have doubt in tcl.. how to Get Subcase and frequency values list in that subcase in hyperworks desktop instead of hyperview.some one can please assist me in this
Thank you in advance
1 - 10 of 101
    llyle_20499User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    https://community.altair.com/community?id=community_question&sys_id=10664cf61b2bd0908017dc61ec4bcbef
    Once you get the IDs, you can use
     poIResultCtrl_handle GetSubcaseLabel id
    to get the labels.
    regards,
    Livil
    OP
    Thank you livil,
    I have a small query ..how to load input file and any results file in hyperview.and using overlay option in hyperview while loading any file.can u please assist me in this please.thank you in advance
    Hi Raj,
    You can add model using:
     poIPost_handle AddModel filename (reader_name)
    and set results using:
     model_handle SetResult file_name (reader_name)
    AddModel by default will overlay the model,.
    OP
    thank you.. really helpful
    how to set  component Colors in hyperview any command to do that..is it possible to add any text to ppt.can u help me
    Thank you..
    For setting colors, get model handle and then use SetColor
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7ba5e203eae5cde3c3e5d4b0926053e3.png
    For PPT, use Automatic Report Director (ARD) it comes with Hyperworks 2019, for earlier versions you will have to install it though PSO installer,
    https://connect.altair.com/CP/downloads.html?suite=Packaged Solution Offerings
    OP
    hi thank you lyle ,
    I am trying to plot graph with above .and I am getting error at selectYComponent step.
    Before that I requested y type and y request and y componentlist also.along with that I used build selectYComponent.though I could not able to get selected YComponent.could u please assist me .. below is the process I followed
    hwi GetSessionHandle sess;
    sess GetClientManagerHandle mgr plot;
    mgr GetBuildPlotsCtrlHandle build;
    #step2:getting y type successfully
    #step3: getting y request successfully
    build SelectYComponent {“ MAG”};-this is not coming and getting error.
    anything do we need to do to get Y component ?.
    thank you in advance Lyle.
    Hi Raj,
    are you getting the build handle?
    sess GetClientManagerHandle pm Plot;
    pm GetBuildPlotsCtrlHandle bp;
    OP
    Hi Lyle,
    yes I am getting build handle .
    And I can able to get X Type,Y type,Y request,but can not able to get Y component.
    As per above pic..I can get all other then y component.
    Any suggestion please assist me..
    I will be helpful
    Thank you
    Hi Raj,
    Can you try after adding 's' to the end of SelectYComponent.
     buildh SelectYComponents {MAG | Z-Trans}
    Share the code and error if you still face issue.
    OP
    Hi Lyle,
    your suggestion is very useful..thank you for that.
    Below is the code for generating curve plot with the below set options.with this I could not able to generate plot..could you please help me in this.where am I getting wrong.can you please check below code ..
    hwi OpenStack
    hwi GetSessionHandle mySession
    mySession GetClientManagerHandle mgr plot
    mgr GetBuildPlotsCtrlHandle bp
    bp SelectDataFile 'file_name' true;
    bp GetSubcaseList
    bp SetSubcase 'subcasename:'
    bp GetDatatypeList true;
    bp GetComponentList true;
    bp GetRequestList true;
    bp SetXDatatype 'time'
    bp SetYDatatype 'Displacement'
    bp SetYRequests {'Node 10'}
    bp SelectYComponents {' MAG'}
    bp GeneratePlots;
    mySession ReleaseHandle
    mgr ReleaseHandle
    bp ReleaseHandle
    hwi CloseStack
