Hi all,
Good afternoon,
I have doubt in tcl.. how to Get Subcase and frequency values list in that subcase in hyperworks desktop instead of hyperview.some one can please assist me in this
Thank you in advance
Once you get the IDs, you can use
poIResultCtrl_handle GetSubcaseLabel id
to get the labels.
regards,
Livil
Thank you livil,
I have a small query ..how to load input file and any results file in hyperview.and using overlay option in hyperview while loading any file.can u please assist me in this please.thank you in advance
Hi Raj,
You can add model using:
poIPost_handle AddModel filename (reader_name)
and set results using:
model_handle SetResult file_name (reader_name)
AddModel by default will overlay the model,.
thank you.. really helpful
how to set component Colors in hyperview any command to do that..is it possible to add any text to ppt.can u help me
Thank you..
For setting colors, get model handle and then use SetColor
For PPT, use Automatic Report Director (ARD) it comes with Hyperworks 2019, for earlier versions you will have to install it though PSO installer,
https://connect.altair.com/CP/downloads.html?suite=Packaged Solution Offerings
hi thank you lyle ,
I am trying to plot graph with above .and I am getting error at selectYComponent step.
Before that I requested y type and y request and y componentlist also.along with that I used build selectYComponent.though I could not able to get selected YComponent.could u please assist me .. below is the process I followed
hwi GetSessionHandle sess;sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
#step2:getting y type successfully
#step3: getting y request successfully
build SelectYComponent {“ MAG”};-this is not coming and getting error.
anything do we need to do to get Y component ?.
thank you in advance Lyle.
are you getting the build handle?
hwi GetSessionHandle sess;sess GetClientManagerHandle pm Plot;
pm GetBuildPlotsCtrlHandle bp;
Hi Lyle,
yes I am getting build handle .
And I can able to get X Type,Y type,Y request,but can not able to get Y component.
As per above pic..I can get all other then y component.
Any suggestion please assist me..
I will be helpful
Thank you
Can you try after adding 's' to the end of SelectYComponent.
buildh SelectYComponents {MAG | Z-Trans}
Share the code and error if you still face issue.
your suggestion is very useful..thank you for that.
Below is the code for generating curve plot with the below set options.with this I could not able to generate plot..could you please help me in this.where am I getting wrong.can you please check below code ..
hwi OpenStack
hwi GetSessionHandle mySession
mySession GetClientManagerHandle mgr plot
mgr GetBuildPlotsCtrlHandle bp
bp SelectDataFile 'file_name' true;
bp GetSubcaseList
bp SetSubcase 'subcasename:'
bp GetDatatypeList true;
bp GetComponentList true;
bp GetRequestList true;
bp SetXDatatype 'time'
bp SetYDatatype 'Displacement'
bp SetYRequests {'Node 10'}
bp SelectYComponents {' MAG'}
bp GeneratePlots;
mySession ReleaseHandle
mgr ReleaseHandle
bp ReleaseHandle
hwi CloseStack
