Result View don't work any more
Zdzislaw
Zdzislaw New Altair Community Member
edited November 2024 in Community Q&A
Aftyer some days of using RM (Win XP + SP3) the Result View don't work any more. Clicking Result icon results in having the icon "graphically pressed" but the Design View does not change to the Result View.
Shall I re-install RM ? Any better idea ?
Regards, Zdzislaw
Answers
  • land
    land New Altair Community Member
    Hi,
    might be you broke the perspective configuration somehow. To revert to the default settings click on the result perspective button and select Restore Default Perspective from the View menu.
    Re-installing won't help, since the configuration files are untouched. To completely revert you need to delete the .RapidMiner5 directory in your user's home directory.
    Greetings,
      Sebastian
  • Zdzislaw
    Thanks a lot ! It has helped. Regards, Zdzislaw
Welcome!
Welcome!
