🎉Community Raffle - Win $25
Join and Win
"Import Wizard crashes"
User: "MuehliMan"
New Altair Community Member
Updated by Jocelyn
Hey all,
When I try to import my Excel file I only get an error: "Data Import Error":
java.lang.NullPointerException
I know this is qquite technical, but maybe someone can interpret the problem already.
Cheers,
Markus
1 - 4 of 41
    User: "MuehliMan"
    OP
    Already solved by myself.
    User: "land"
    Well,
    even if you have solved the problem: Would you please send us the bugreport? In no cases there should occur a null pointer exception.
    Greetings,
      Sebastian
    User: "schills"
    Hello
    I have had the same problem since updating to the newest version of rapid miner (5.1.015), which never used to happen on the older version of rapid miner. May i ask what was the solution?
    Andrew
    User: "schills"
    Further to the above i have also started a new topic called "Data Import wizard crashes - Java NullPointerException" which details more of the problems i am encountering
    Cheers
    Andrew
