🎉Community Raffle - Win $25
Join and Win
"Compare Weka and RM Random Forest"
User: "MuehliMan"
New Altair Community Member
Updated by Jocelyn
Hi,
During my last calculations I did from runs with Random Forest and the Weka Random Forest Operator using various options. Although I tried to make both operators equivalent (using the same number of trees, same local random seed, no minimal split features etc.)  the perfomance of the two operators were still different. Here is the workflow I used for benchmarking the two operators.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.1.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process">
    <process expanded="true" height="269" width="949">
      <operator activated="true" class="generate_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
        <parameter key="number_of_attributes" value="20"/>
      </operator>
      <operator activated="true" class="discretize_by_user_specification" compatibility="5.1.001" expanded="true" height="94" name="Discretize" width="90" x="179" y="30">
        <parameter key="attribute_filter_type" value="single"/>
        <parameter key="attribute" value="label"/>
        <parameter key="include_special_attributes" value="true"/>
        <list key="classes">
          <parameter key="first" value="0.5"/>
          <parameter key="last" value="Infinity"/>
        </list>
      </operator>
      <operator activated="true" class="nominal_to_binominal" compatibility="5.1.001" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="30">
      </operator>
      <operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="94" name="Multiply" width="90" x="447" y="30"/>
      <operator activated="true" class="weka:W-RandomForest" compatibility="5.0.001" expanded="true" height="76" name="W-RandomForest" width="90" x="581" y="120">
        <parameter key="S" value="1992.0"/>
        <parameter key="depth" value="5"/>
        <parameter key="D" value="true"/>
      </operator>
      <operator activated="true" class="apply_model" compatibility="5.1.001" expanded="true" height="76" name="Apply Model (2)" width="90" x="715" y="120">
      </operator>
      <operator activated="true" class="performance_binominal_classification" compatibility="5.1.001" expanded="true" height="76" name="Weka Random Forest" width="90" x="849" y="120">
        <parameter key="f_measure" value="true"/>
        <parameter key="youden" value="true"/>
      </operator>
      <operator activated="true" class="random_forest" compatibility="5.1.001" expanded="true" height="76" name="Random Forest" width="90" x="581" y="30">
        <parameter key="minimal_size_for_split" value="1"/>
        <parameter key="minimal_leaf_size" value="1"/>
        <parameter key="minimal_gain" value="0.0"/>
        <parameter key="maximal_depth" value="5"/>
        <parameter key="confidence" value="1.0E-7"/>
        <parameter key="no_pre_pruning" value="true"/>
        <parameter key="no_pruning" value="true"/>
        <parameter key="use_local_random_seed" value="true"/>
      </operator>
      <operator activated="true" class="apply_model" compatibility="5.1.001" expanded="true" height="76" name="Apply Model" width="90" x="715" y="30">
      </operator>
      <operator activated="true" class="performance_binominal_classification" compatibility="5.1.001" expanded="true" height="76" name="RM Random Forest" width="90" x="849" y="30">
      </operator>
      <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/>
      <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
      <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Multiply" to_port="input"/>
      <connect from_op="Multiply" from_port="output 1" to_op="Random Forest" to_port="training set"/>
      <connect from_op="Multiply" from_port="output 2" to_op="W-RandomForest" to_port="training set"/>
      <connect from_op="W-RandomForest" from_port="model" to_op="Apply Model (2)" to_port="model"/>
      <connect from_op="W-RandomForest" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/>
      <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Weka Random Forest" to_port="labelled data"/>
      <connect from_op="Weka Random Forest" from_port="performance" to_port="result 2"/>
      <connect from_op="Random Forest" from_port="model" to_op="Apply Model" to_port="model"/>
      <connect from_op="Random Forest" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/>
      <connect from_op="Apply Model" from_port="labelled data" to_op="RM Random Forest" to_port="labelled data"/>
      <connect from_op="RM Random Forest" from_port="performance" to_port="result 1"/>
      <portSpacing port="sink_result 3" spacing="0"/>
    </process>
  </operator>
</process>
Is RM using a different implentation of the Random Forest and if so, what differences were useed?
Best regards,
Markus
1 - 4 of 41
    User: "land"
    Hi,
    this is a completely different implementation of the same algorithms. That means, there are many small differences in the way values are computed and stored causing for example small rounding deviations. In the end the results may look different.
    Greetings,
    Sebastian
    User: "MuehliMan"
    OP
    Hi Sebastian,
    if that is the case, why do I totally different values for the performance, given by accuary for example).
    Wekas accuracy: 100%
    RMs accuracy: 61%
    (obtained with the posted workflow)
    Best,
    Markus
    User: "haddock"
    Hi folks,
    Mmm... if a model gets 100% accuracy when applied to its own training data, especially when that data is random, then one should suspect over-fitting, and low predictive power - so RapidMiner wins again  ;) . Models are only good if they work equally well on unseen data, as this link explains..
    http://en.wikipedia.org/wiki/Overfitting
    Good weekend to all!
    User: "MuehliMan"
    OP
    I am not interested who wins or looses, but in the reason why the results are different. This was a benchmarking example more than a real-use problem.
    As far as I know Breiman included a bootstrapping as validation for the random forest to avoid overfitting.
    BTW: Enabling or disabling the two pruning options do not change the results.
    Nice weekend and a happy new year to you too!
    Cheers,
    Markus
