Altair RISE
Nominate Yourself Now!
Rapidminer not starting up
User: "sruefer"
New Altair Community Member
Updated by Jocelyn
Hi,
my Rapidminer 5 installation suddenly does not start up anymore. When clicking the icon (and also when starting as Administrator), the startup splash screen appears, notifying me that operators are being initialized. However, there is no further progress, and I have to terminate the application manually. Last time I run the application successfully was about 3-4 weeks ago.
I uninstalled and re-installed the entire program, but the problem persists. I am using Windows 7, 64bit.
Could there be a problem with the Java Runtime Environment? I had an error message once after terminating Rapidminer; I have the latest version (1.6) installed, there are no newer updates available.
Is there an error or startup log file somewhere that I can check? Or any other obvious things I am missing?
Thank you, kind regards,
Steffen
