rapidminer.init.plugins=true
2011-01-04 11:45:18 CONFIG: Locale not specified explicitly. Set default locale to US. (RapidMiner.init())2011-01-04 11:45:18 INFO: Property rapidminer.home is not set. Guessing. (Launcher.ensureRapidMinerHomeSet())2011-01-04 11:45:18 INFO: Trying base directory of classes (build) 'C:\RapidMiner_Vega'...gotcha! (Launcher.ensureRapidMinerHomeSet())2011-01-04 11:45:18 CONFIG: Reading configuration resource com/rapidminer/resources/rapidminerrc. (ParameterService.loadAllRCFiles())2011-01-04 11:45:18 CONFIG: Neither system property 'rapidminer.config.dir' nor environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())2011-01-04 11:45:18 CONFIG: Trying rcfile 'C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\.RapidMiner5\5_0_8_rapidminerrc'...skipped (ParameterService.loadRCFile())2011-01-04 11:45:18 CONFIG: Read rcfile 'C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\.RapidMiner5\5_0_8_rapidminerrc.Windows XP'. (ParameterService.loadRCFile())2011-01-04 11:45:18 CONFIG: Trying rcfile 'C:\RapidMiner_Vega\rapidminerrc'...skipped (ParameterService.loadRCFile())2011-01-04 11:45:18 CONFIG: Trying rcfile 'C:\RapidMiner_Vega\rapidminerrc.Windows XP'...skipped (ParameterService.loadRCFile())2011-01-04 11:45:18 CONFIG: Property rapidminer.rcfile not specified...skipped (ParameterService.loadAllRCFiles())2011-01-04 11:45:18 CONFIG: Read extension state. (ManagedExtension.readConfiguration())2011-01-04 11:45:18 CONFIG: Plugin directory C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\.RapidMiner5\managed\extensions.xml does not exist. (Plugin.findAndRegisterPlugins())2011-01-04 11:45:18 CONFIG: Loading renderers from 'Text Processing'. (RendererService.init())2011-01-04 11:45:18 CONFIG: Reading parse rules from jar:file:/C:/Documents%20and%20Settings/Administrator.KNOWLEDG-P6715Y/.RapidMiner5/managed/rmx_text-5.1.0.jar!/com/rapidminer/resources/parserulesTextProcessing.xml (XMLImporter.importParseRules())2011-01-04 11:45:18 CONFIG: Loading renderers from 'Web Mining'. (RendererService.init())2011-01-04 11:45:18 CONFIG: Reading parse rules from jar:file:/C:/Documents%20and%20Settings/Administrator.KNOWLEDG-P6715Y/.RapidMiner5/managed/rmx_web-5.0.4.jar!/com/rapidminer/resources/parserulesWeb.xml (XMLImporter.importParseRules())2011-01-04 11:45:18 CONFIG: Loading renderers from 'Series'. (RendererService.init())2011-01-04 11:45:18 CONFIG: Reading parse rules from jar:file:/C:/Documents%20and%20Settings/Administrator.KNOWLEDG-P6715Y/.RapidMiner5/managed/rmx_series-5.0.2.jar!/com/rapidminer/resources/parserulesValueSeries.xml (XMLImporter.importParseRules())2011-01-04 11:45:18 CONFIG: Loading operators from 'OperatorsCore.xml'. (OperatorService.registerOperators())2011-01-04 11:45:18 CONFIG: Loading operator documentation from file:/C:/RapidMiner_Vega/build/com/rapidminer/resources/i18n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())2011-01-04 11:45:19 WARNING: Password in XML file looks like unencrypted plain text. (ParameterTypePassword.decryptPassword())2011-01-04 11:45:20 CONFIG: Loading operators from 'C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\.RapidMiner5\managed\rmx_text-5.1.0.jar'. (OperatorService.registerOperators())2011-01-04 11:45:20 CONFIG: Loading operator documentation from jar:file:/C:/Documents%20and%20Settings/Administrator.KNOWLEDG-P6715Y/.RapidMiner5/managed/rmx_text-5.1.0.jar!/com/rapidminer/resources/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLControl.newBundle())Exception in thread "main" java.lang.VerifyError: (class: com/rapidminer/operator/text/io/DocumentLoader, method: read signature: ()Lcom/rapidminer/operator/text/Document;) Incompatible argument to function at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:89) at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:282) at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:279) at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:279) at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:255) at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:229) at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:430) at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:631) at com.rapidminer.tools.OperatorService.init(OperatorService.java:188) at com.rapidminer.RapidMiner.init(RapidMiner.java:402) at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:211) at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:554) at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:536)
rapidminer.init.plugins=false
@Haddock:It seems that this is a pretty related issue, namely that the methods has (slightly) changed between the RapidMiner version you has programmed your extension against and the latest version in Eclipse updated via SVN. Could this be?
Or maybe there is an old version of your extension installed in your system (e.g. in the plugins dir or in your home dir)?
