"Help with Word List Operator"
I am trying to add the WordList Operator to this Word Vector code I am working on. I cannot enable it properly. I would appreciate any suggestions on implementing the WordList Operator. I wanted to add it to the end so I can get a list of each word with a count.
Thanks,
Ron McEwan
Thanks,
Ron McEwan
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process">
<process expanded="true" height="431" width="413">
<operator activated="true" class="web:get_webpage" compatibility="5.0.4" expanded="true" height="60" name="Get Page" width="90" x="55" y="46">
<parameter key="url" value="http://seekingalpha.com/news/market_currents?source=refreshed"/>
<list key="query_parameters"/>
</operator>
<operator activated="true" class="text:tokenize" compatibility="5.0.7" expanded="true" height="60" name="Tokenize" width="90" x="202" y="41"/>
<operator activated="true" class="text:extract_length" compatibility="5.0.7" expanded="true" height="60" name="Extract Length" width="90" x="112" y="165"/>
<operator activated="true" class="text:extract_token_number" compatibility="5.0.7" expanded="true" height="60" name="Extract Token Number" width="90" x="246" y="165"/>
<connect from_op="Get Page" from_port="output" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Extract Length" to_port="document"/>
<connect from_op="Extract Length" from_port="document" to_op="Extract Token Number" to_port="document"/>
<connect from_op="Extract Token Number" from_port="document" to_port="result 1"/>
</process>
</operator>
</process>
1 - 4 of
41
check out my blog this week. i've got 5 videos all about text mining, and this should answer your question.
Hi Ron,
it seems you didn't create a word vector so far. You can use the "Process Documents" operator to simply do this. If you only need the term occurences it's a very simple extension of your example code:
Matthias
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Regards,
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="431" width="681">
<operator activated="true" class="web:get_webpage" compatibility="5.0.4" expanded="true" height="60" name="Get Page" width="90" x="45" y="30">
</operator>
<operator activated="true" class="text:process_documents" compatibility="5.0.6" expanded="true" height="94" name="Process Documents" width="90" x="313" y="30">
<parameter key="vector_creation" value="Term Occurrences"/>
<process expanded="true" height="607" width="786">
<operator activated="true" class="text:tokenize" compatibility="5.0.6" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:extract_length" compatibility="5.0.6" expanded="true" height="60" name="Extract Length" width="90" x="246" y="30"/>
<operator activated="true" class="text:extract_token_number" compatibility="5.0.6" expanded="true" height="60" name="Extract Token Number" width="90" x="380" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Extract Token Number" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<connect from_op="Get Page" from_port="output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
Matthias
