Altair RISE
Nominate Yourself Now!
ERROR # 2113
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello there,
I am working on setting up an Optistruct model for a FSAE carbon fiber monocoque.
The bearings of the suspension arms are modeled as RBE2s with the corresponding DOFs.
In order to get the suspension to articulate somewhat realistically, I have added local coordinate systems that align with axes of the suspension components.
This way, the dependent nodes of the RBE2s can be assigned to the local coordinate system in order to set accurate DOFs for each rigid.
I attached a picture just for visual clarification of what I mean.
When modeling the first coordinate system and completing the steps listed above, the model solved.
When I create a second coordinate system in the same manner, I get this error below:
 *** ERROR # 2113 ***
 Invalid coordinate system CORD3R, id =          2
    Coordinates of the 3 defining points are:
    point 1 -  -2.285920e+001   5.969279e+001   5.722970e+001
    point 2 -  -2.285970e+001   5.664590e+001   6.421403e+001
    point 3 -  -2.286030e+001   5.359900e+001   7.119836e+001
Any input is appreciated.
Thank you for your time.
Chris McCloskey
Michigan State Formula Racing
mcclos36@msu.edu
1 - 1 of 11
    User: "Vinicius"
    Altair Community Member
    Updated by Vinicius
    Hello Chris to solve this problem you have to create a local coordinate system for each element, and after creating the element, associate it with each system. To do this, create a local coordinate system on the systems tab. After that, click on Card Edit and select the spring element. After that, click on edit and in CID select the local coordinate system. I would like to point out that I am doing this for the spring element, but this should help you.
    Best Regards.
