calculate rows
gritsay
gritsay New Altair Community Member
edited November 2024 in Community Q&A
Hello! What I can execute add or minus data from rows?
For example, source table:
name    | original series | smoothing series |
param1 |  12                |  13
param2 |  11                |  13
param3 |  22                |  21
Postprocessing table:
name    | original series | smoothing series |  sum  | minus|
param1 |  12                |  13                    | 25    |-1      |
param2 |  11                |  13                    | 24    |-2      |
param3 |  22                |  21                    | 43    | 1      |
Which operator should I use ?
Answers
  • colo
    colo New Altair Community Member
    I would suggest the "Generate Attributes" operator. It allows the creation of new attributes while referencing existing attributes and using expressions (including some useful functions) is possible. If you have the attributes "att1" and "att2" you can create the new attributes sum (att1 + att2) and minus (att1 - att2) easily. You should not use blanks or special characters inside the attribute names to avoid problems here.
    Regards,
    Matthias
  • gritsay
    Thanks! It's very just. :)
Welcome!
Welcome!
