Altair RISE
Nominate Yourself Now!
Constraint/boundary condition
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
A simple question!  How does one change/modify one or a few of constraints applied on a model.  This can be easily done in all FE software I have used (five of them), yet, I cannot figure out how to do it in Hypermesh).
When I used the 'update' route, I noticed both the old BCs and revised ones appearing in the solver deck.
Help!
1 - 3 of 31
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    Perhaps your manipulation was wrong somewhere.
    In panel analysis>constraints>update, click to select constraints, modify parameters (dofs, load types,...) then click 'update' > confirm what you want to update > click 'update'
    Altair Employee
    OP
    Dear Tinh:
    Thank you very much.  Perhaps I should have made my question a bit more precise.  What I was wanting to know is that after removing the boundary condition, how can one get rid of the triangle that s connected to the removed boundary condition.  The procedure you outlined (which I knew about it), gets rid of the BC, by removing the DOF number associated to the selected node, but not the triangle.
    Thank you very much for your help!
    User: "tinh"
    Updated by tinh
    Hi
    If you want to remove bcs, enter panel delete (press F2), change entity type to 'loads' pick bcs then 'delete'
