"Average over Random Forest - Tree Importance Weights"
MuehliMan
MuehliMan New Altair Community Member
edited November 2024 in Community Q&A
Hi all,
here is another thing I would need your help. Random Forest (Weighting) is giving different attributes every run (due to the random selection of attributes I guess).  I would like to perform the Random Forest multiple times and average over all weights to see, when the weights converge.
Here is my basic workflow, but I do not know how to average over all weights in the paramter loop.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process">
   <process expanded="true" height="388" width="1065">
     <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
       <parameter key="number_examples" value="200"/>
       <parameter key="number_of_attributes" value="100"/>
     </operator>
     <operator activated="true" class="discretize_by_user_specification" compatibility="5.0.8" expanded="true" height="94" name="Discretize" width="90" x="179" y="30">
       <parameter key="attribute_filter_type" value="single"/>
       <parameter key="attribute" value="label"/>
       <parameter key="include_special_attributes" value="true"/>
       <list key="classes">
         <parameter key="0" value="0.5"/>
         <parameter key="1" value="1.0"/>
       </list>
     </operator>
     <operator activated="true" class="nominal_to_binominal" compatibility="5.0.8" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="30">
     </operator>
     <operator activated="true" class="generate_id" compatibility="5.0.8" expanded="true" height="76" name="Generate ID" width="90" x="447" y="30"/>
     <operator activated="true" class="loop_parameters" compatibility="5.0.10" expanded="true" height="76" name="Loop Parameters" width="90" x="581" y="30">
       <list key="parameters">
         <parameter key="Random Forest.local_random_seed" value="[333;33333333;1000;linear]"/>
       </list>
       <process expanded="true" height="388" width="979">
         <operator activated="true" class="random_forest" compatibility="5.0.10" expanded="true" height="76" name="Random Forest" width="90" x="45" y="30">
           <parameter key="criterion" value="gini_index"/>
           <parameter key="maximal_depth" value="5"/>
           <parameter key="use_local_random_seed" value="true"/>
           <parameter key="local_random_seed" value="1866981"/>
         </operator>
         <operator activated="true" class="weight_by_forest" compatibility="5.0.10" expanded="true" height="76" name="Weight by Tree Importance" width="90" x="180" y="30">
         </operator>
         <operator activated="true" class="weights_to_data" compatibility="5.0.10" expanded="true" height="60" name="Weights to Data" width="90" x="313" y="30"/>
         <connect from_port="input 1" to_op="Random Forest" to_port="training set"/>
         <connect from_op="Random Forest" from_port="model" to_op="Weight by Tree Importance" to_port="random forest"/>
         <connect from_op="Weight by Tree Importance" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/>
         <portSpacing port="source_input 2" spacing="0"/>
         <portSpacing port="sink_performance" spacing="0"/>
       </process>
     </operator>
     <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/>
     <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
     <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
     <connect from_op="Generate ID" from_port="example set output" to_op="Loop Parameters" to_port="input 1"/>
   </process>
 </operator>
</process>
Welcome!
Answers
  • fischer
    fischer New Altair Community Member
    Hi,
    I think you can use "Loop and Average" for your purposes.
    Best,
    Simon
  • MuehliMan
    But I want to use different random seeds as well. Is that still possible? (I got the tip to use loop parameter to obtain new random seeds by Ingo.)
    UPDATE: I tested a random forest looped over different number of trees (10 to 1000) and each number of trees I looped 50 times using different local random seeds. What surprised me most was that only some (almost discrete) performances appeared in the trees vs performance plot. (I could supply the plot if needed. ) I am aksing myself (and you) if this occurs because of the random seeds or the number of attributes.
  • fischer
    Hi,
    if the hypothesis space is limited, it is not uncommon that you only observe a limited number of possible performances. This certainly depends on the number of attributes you have (and whether these are actually used by the model).
    Best,
    Simon
Welcome!
Welcome!
