KMeans - different output on the same data
Shubha
Shubha New Altair Community Member
edited November 2024 in Community Q&A
Hi,
Please find the below code:
<operator name="Root" class="Process" expanded="yes">
    <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
        <parameter key="target_function" value="sum classification"/>
        <parameter key="number_examples" value="50"/>
    </operator>
    <operator name="IOMultiplier" class="IOMultiplier">
        <parameter key="io_object" value="ExampleSet"/>
    </operator>
    <operator name="KMeans" class="KMeans">
    </operator>
    <operator name="IOSelector" class="IOSelector">
        <parameter key="select_which" value="2"/>
    </operator>
    <operator name="KMeans (2)" class="KMeans">
    </operator>
</operator>
I have generated a dataset(required for KMeans) and made a copy of the same, so now I have 2 copies of the same dataset. I then apply the "KMeans" operator on both the examplesets. But the cluster centroids and also the cluster groupings are different for two examplesets. Why is this? Is it dependent on some seed value?
If I re-run the code, the same examplesets are generated with the same cluster centroids and groupings for the first and second examplesets. Why is is this? I then clicked the option, "use_local_random_seed" in KMeans. This made the cluster centroids and grouping look identical for both the data.
Questions:
1. What actually happens by the usage of "use_local_random_seed"?
2. The cluster centroids and groupings of the first and second examplesets are always the same irrespective of how many times we run it. But the KMeans applied on the same data in a single run is always different. Does this mean, RM when detects a KMeans operator for the first time applies a seed "A" and for the second time "B" always?
3. How do we choose the "use_local_random_seed"? What are its minimum and maximum values?
4. For simplicity, one can consider the below code too.
    </operator>
    <operator name="KMeans" class="KMeans" breakpoints="before">
    </operator>
    <operator name="KMeans (2)" class="KMeans" breakpoints="before">
    </operator>
</operator>
Many Thanks,
Shubha.
Welcome!
Answers
  • haddock
    haddock New Altair Community Member
    There has been quite a lot of discussion recently about random numbers, did you read it?
  • Shubha
    Thanks Haddock. That was helpful reading the thread, http://rapid-i.com/rapidforum/index.php/topic,2251.0.html.
    I encountered another problem with respect to KMedoids.
    The code below:
        </operator>
        <operator name="KMedoids" class="KMedoids" breakpoints="before">
        </operator>
        <operator name="KMedoids (2)" class="KMedoids" breakpoints="before">
        </operator>
        <operator name="KMedoids (3)" class="KMedoids" breakpoints="before">
        </operator>
        <operator name="KMedoids (4)" class="KMedoids" breakpoints="before">
        </operator>
    </operator>
    The operators, "KMedoids", "KMedoids (2)", "KMedoids (3)" and "KMedoids (4)" all have same options, though "KMedoids" behave different than the other KMedoids operators.
    "KMedoids" have centroid value of Cluster 0 as
    Cluster 0 att1:1.395    att2:5.951    att3:2.581    att4:-0.637    att5:-2.674
    The "KMedoids (2)",  "KMedoids (3)" and "KMedoids (4)" has centroid values of cluster 0 as:
    Cluster 0 att1:3.270    att2:-7.064    att3:-2.953    att4:-4.882    att5:6.055
    After "KMedoids (4)", I tried introducing other KMedoids operators, still the same centorid vaues of "KMedoids (2)" prevail.
    So, then I introduced "KMedoids (5)" by COPYING "KMedoids" operator. Then to my surprise, the centroid values of cluster 0 is same as "KMedoids", instead of "KMedoids (2)"....
    But identically "KMedoids", "KMedoids (2)", "KMedoids (3)", "KMedoids (4)" and "KMedoids (5)" are all the same with local random seed -1.
    Thanks,
    Shubha
  • haddock
    Is this 4.6 code?
  • Shubha
    No, Its actually 4.4. Due to some contraints at this stage cannot switch to the newer version.
  • Shubha
    But, is this dependent on the version?
    Thanks,
    Shubha.
  • haddock
    Well yes. 4.4 is no longer supported here by RM, so you need someone else with 4.4 to verify your problem. Good luck with that!!!
Welcome!
Welcome!
