Checking for repeating ID?
dragoljub
dragoljub New Altair Community Member
edited November 2024 in Community Q&A
Hi Guys,
Sometimes I create an ID attribute from part numbers x,y locations etc and if there is ever a repeating sample in my large data set it would be nice to see. I am surprised that RM lets the ID attribute contain repeating values.
What is the quickest way to check if there are any repeating values (not necessarily nominal) for a particular attribute?
It would be cool if there was a meta data column for that.
-Gagi
Welcome!
Answers
  • land
    land New Altair Community Member
    Hi Gagi,
    in fact there is a meta data value for this: Take a look at the mode, this is the most frequent nominal value. If this value occurs just once, then each value is unique.
    Greetings,
      Sebastian
  • dragoljub
    I guess my problem is my ID is an integer but stored as a real.
    Will mode only be computed for nominal attributes?
    Thanks,
    -Gagi
  • land
    Hi Gagi,
    that's true: Mode is only calculated for nominal data. You could use Numerical to Polynomial to convert it.
    Greetings,
      Sebastian
  • dragoljub
    Ahh now that makes sense. Thanks!
    -Gagi  ;D
Welcome!
Welcome!
