1 - 6 of
61
Oh, I must than have misunderstood
The answer still is the same: Read the text given in the links, they also give a motivation in which situations the operator can be applied.
Cheers,
Ingo
By reading your statement again it of course says "I need a motivation" for using it
But what exactly does it do?
Cheers,
Ingo
as far as i understood the content given in the link this operator can be used to get sum of each product in the data set.
But in which cases do i need to know how much e.g. apple i got in the Data set. That was my question.
Both links say 'u can use the aggregate for sum, average etc. but when is it useful in Association analysis...
greetings
Lotus
greetings
Lotus
Hi,
If this is useful in association analysis or not can not be answered in general. If you want to search for associations in aggregations you will probably need the aggregation operator. Don't forget that you could define several attribute which should be used for grouping and in that case you will end up with several transactions containing different sums of apples / bananas / ... for different groups - what is quite similar to different items for different transactions.
If you are not aiming at something like that, you probably won't need it. It's as simple as that.
Cheers,
Ingo
No, is was not. But anyway...
Cheers,
Ingo
it does basically the same thing as the aggregation known from databases (group by plus aggregation function). Here are some infos:
http://www.sqlcommands.net/sql+group+by/
http://www.w3schools.com/sql/sql_groupby.asp
Cheers,
Ingo
