Altair RISE
Nominate Yourself Now!
"which ROC curve comes together with which model?"
User: "dan_agape"
New Altair Community Member
Updated by Jocelyn
Hi again
If you display the performance information regarding several classification models – how do you distinguish which ROC curve corresponds to which model? I do not see anything on the ROC curve windows identifying the corresponding model. Thanks for your suggestions/comments
Dan
1 - 8 of 81
    User: "land"
    Hi,
    normally the result tabs show the names of the operators that created the respective result. So you might take a look there?
    Greetings,
      Sebastian
    User: "dan_agape"
    OP
    Sebastian, thanks. However I am still confused. Do you mean the correspondence between a model and its performance vector (if you build and evaluate several models in the same canvas) is made via the name of the operators that built these? In this case the operator for evaluation is the same. i.e. "Performance". Some numbers are also included in the tabs of these windows - do you mean these numbers are to be used to know which performance correspond to which model?
    Greetings
    Dan
    User: "land"
    Hi Dan,
    now I'm confused :) Let's make a common base to talk about: Please replace the data source you use in your process by an Generate Data operator and then paste the process here in the code area. The code area can be inserted with the # button above.
    Then I will see what you see and probably will understand better what we are talking about :)
    Greetings,
      Sebastian
    User: "dan_agape"
    OP
    Sebastian, here is a process building 3 models and their performances. Just to repeat the question: how do you know which performance corresponds to which model in the result windows?
    Thanks
    Dan
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
        <parameter key="logverbosity" value="3"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="1"/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <parameter key="parallelize_main_process" value="false"/>
        <process expanded="true" height="467" width="465">
          <operator activated="true" class="generate_churn_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Churn Data" width="90" x="45" y="165">
            <parameter key="number_examples" value="1000"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="112" name="Multiply" width="90" x="179" y="165"/>
          <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation (2)" width="90" x="313" y="165">
            <parameter key="create_complete_model" value="false"/>
            <parameter key="split" value="1"/>
            <parameter key="split_ratio" value="0.7"/>
            <parameter key="training_set_size" value="100"/>
            <parameter key="test_set_size" value="-1"/>
            <parameter key="sampling_type" value="1"/>
            <parameter key="parallelize_training" value="false"/>
            <parameter key="parallelize_testing" value="false"/>
            <process expanded="true" height="422" width="243">
              <operator activated="true" class="k_nn" compatibility="5.0.8" expanded="true" height="76" name="k-NN" width="90" x="112" y="30">
                <parameter key="k" value="5"/>
                <parameter key="weighted_vote" value="false"/>
                <parameter key="measure_types" value="0"/>
                <parameter key="mixed_measure" value="0"/>
                <parameter key="nominal_measure" value="0"/>
                <parameter key="numerical_measure" value="0"/>
                <parameter key="divergence" value="0"/>
                <parameter key="kernel_type" value="1"/>
                <parameter key="kernel_gamma" value="1.0"/>
                <parameter key="kernel_sigma1" value="1.0"/>
                <parameter key="kernel_sigma2" value="0.0"/>
                <parameter key="kernel_sigma3" value="2.0"/>
                <parameter key="kernel_degree" value="3.0"/>
                <parameter key="kernel_shift" value="1.0"/>
                <parameter key="kernel_a" value="1.0"/>
                <parameter key="kernel_b" value="0.0"/>
              </operator>
              <connect from_port="training" to_op="k-NN" to_port="training set"/>
              <connect from_op="k-NN" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
              <portSpacing port="sink_model" spacing="0"/>
              <portSpacing port="sink_through 1" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (2)" width="90" x="24" y="29">
                <parameter key="create_view" value="false"/>
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance (2)" width="90" x="108" y="123">
                <parameter key="use_example_weights" value="true"/>
              </operator>
              <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
              <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
              <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="source_model" spacing="0"/>
              <portSpacing port="source_test set" spacing="0"/>
              <portSpacing port="source_through 1" spacing="0"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="313" y="30">
            <parameter key="sampling_type" value="stratified sampling"/>
              <operator activated="true" class="decision_tree" compatibility="5.0.8" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30">
                <parameter key="criterion" value="gain_ratio"/>
                <parameter key="minimal_size_for_split" value="4"/>
                <parameter key="minimal_leaf_size" value="2"/>
                <parameter key="minimal_gain" value="0.1"/>
                <parameter key="maximal_depth" value="20"/>
                <parameter key="confidence" value="0.25"/>
                <parameter key="number_of_prepruning_alternatives" value="3"/>
                <parameter key="no_pre_pruning" value="false"/>
                <parameter key="no_pruning" value="false"/>
              </operator>
              <connect from_port="training" to_op="Decision Tree" to_port="training set"/>
              <connect from_op="Decision Tree" from_port="model" to_port="model"/>
            </process>
            <process expanded="true" height="422" width="279">
              <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance" width="90" x="112" y="165">
              </operator>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
            </process>
          </operator>
          <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="130" name="Validation (4)" width="90" x="313" y="300">
              <operator activated="true" class="naive_bayes" compatibility="5.0.8" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="81" y="30">
                <parameter key="laplace_correction" value="true"/>
              </operator>
              <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/>
              <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model (4)" width="90" x="45" y="30">
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="Performance (4)" width="90" x="112" y="165">
              </operator>
              <connect from_port="model" to_op="Apply Model (4)" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/>
              <connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance (4)" to_port="labelled data"/>
              <connect from_op="Performance (4)" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="sink_averagable 3" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Generate Churn Data" from_port="output" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Validation (2)" to_port="training"/>
          <connect from_op="Multiply" from_port="output 3" to_op="Validation (4)" to_port="training"/>
          <connect from_op="Validation (2)" from_port="averagable 1" to_port="result 4"/>
          <connect from_op="Validation" from_port="model" to_port="result 1"/>
          <connect from_op="Validation" from_port="training" to_port="result 2"/>
          <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
          <connect from_op="Validation (4)" from_port="model" to_port="result 5"/>
          <connect from_op="Validation (4)" from_port="averagable 1" to_port="result 6"/>
          <portSpacing port="sink_result 3" spacing="0"/>
          <portSpacing port="sink_result 4" spacing="108"/>
          <portSpacing port="sink_result 5" spacing="72"/>
          <portSpacing port="sink_result 6" spacing="18"/>
          <portSpacing port="sink_result 7" spacing="0"/>
        </process>
      </operator>
    </process>
    User: "haddock"
    Just to repeat the answer....
    Like this...
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          </operator>
              </operator>
            </process>
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="B" width="90" x="108" y="123"/>
              <connect from_op="Apply Model (2)" from_port="labelled data" to_op="B" to_port="labelled data"/>
              <connect from_op="B" from_port="performance" to_port="averagable 1"/>
            </process>
          </operator>
              <operator activated="true" class="decision_tree" compatibility="5.0.8" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/>
            </process>
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="A" width="90" x="112" y="165"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="A" to_port="labelled data"/>
              <connect from_op="A" from_port="performance" to_port="averagable 1"/>
            </process>
          </operator>
          <operator activated="true" class="split_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation (4)" width="90" x="313" y="300">
              <operator activated="true" class="naive_bayes" compatibility="5.0.8" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="81" y="30"/>
            </process>
              </operator>
              <operator activated="true" class="performance" compatibility="5.0.8" expanded="true" height="76" name="C" width="90" x="112" y="165"/>
              <connect from_op="Apply Model (4)" from_port="labelled data" to_op="C" to_port="labelled data"/>
              <connect from_op="C" from_port="performance" to_port="averagable 1"/>
            </process>
          </operator>
        </process>
      </operator>
    </process>
    User: "land"
    Hi,
    as I said, the name of the generating operator is shown in the tabs. Since you did not rename your performance estimating operators they are simply numbered: Performance, Performance (2) and Performance (4). The tab names in the result perspectives are "PerformanceVector (Performance)", "PerformanceVector (Performance (2))"...
    So if you give your operators meaningful names, you will know which tab represents which result...
    Greetings,
      Sebastian
    User: "dan_agape"
    OP
    Sebastian thanks!
    User: "land"
    No Problem :)
